Garlou
Jun 22, 2020Aspirant
Trouble upgrading firmware R7000-V1.0.11.100_10.2.100
So I got an email saying I need to upgrade my firmware, so I went on the Netgear site and downloaded the software. It came in a folder and the file said: R7000-V1.0.11.100_10.2.100.chk which I co...
- Jun 24, 2020
Those mass mailings go out from time to time. They aren't the result of Netgear inspecting your router and checking its firmware.
Garlou wrote:
So I opened up http://www.routerlogin.net and went to Advanced and then Administration, and then clicked on Router Update and saw my firmware version was V1.0.9.88_10.2.88 but when I clecked on Check, it said No new firmware version available.
That's not reliable either. It can miss "hotfix" updates, for example.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware for your device.
Check the section in the manual about manual updates.
TOOMUCHSAUCE
Jun 24, 2020Apprentice
Download the firmware manually. Unzip and drop the *.chk file on your desktop. Log into your router, go to Advanced--> Admin --> Router Upgrade. There you can manually browse to the firmware file. Do that and select upload.
Garlou
Jun 24, 2020Aspirant
Thank you!
Did this and it upgraded fine. I was just confused because it said no new updates were needed.
Lou
