ill
Jun 10, 2017Aspirant
Trouble with Denon AVR-X4300H Accessing Nighthawk X4S AC2600 R7800 Home WiFi Network
Purchased a Denon AVR-X4300H and I'm trying access my home wifi network. I'm using Netgear Nighthawk X4S AC2600 Model R7800. Is there anyone on this forum familiar with the unit? Thank you for help.
- Jun 11, 2017FURRYe38,
I went into Setup\Network\WiFi Setup and the AVR scanned for wifi networks. When it displayed mine I entered the password for the 5GHz band. That was it.
William10a
Jun 10, 2017Master
From the instructions it sounds simple on the Denon unit scan for wifi signals and select your's and enter your password for the network.
Here is a link to denon's manual https://usa.denon.com/us/product/hometheater/receivers/avrx4300h
I hope this by the look at page 237 in the manual good luck .
- illJun 11, 2017Aspirant
Thanks William10a. I figured it out last night shortly after I began this thread. I was a bit over tired and not thinking clearly.
