ill
Jun 10, 2017Aspirant
Trouble with Denon AVR-X4300H Accessing Nighthawk X4S AC2600 R7800 Home WiFi Network
Purchased a Denon AVR-X4300H and I'm trying access my home wifi network. I'm using Netgear Nighthawk X4S AC2600 Model R7800. Is there anyone on this forum familiar with the unit? Thank you for help.
- Jun 11, 2017FURRYe38,
I went into Setup\Network\WiFi Setup and the AVR scanned for wifi networks. When it displayed mine I entered the password for the 5GHz band. That was it.
Jun 11, 2017Guru - Experienced User
Does the AVR have a wired LAN port as well? I recommend using LAN port for best performances if your goingto use an AVR.
William10a
Jun 11, 2017Master
From I saw yes it has a 100mb wired lan port depending where the amp is located and the router located yours may be the best answer since in the end it all comes down to a static ip address on the network for the amp's network interface.
In fact it is on page 86,87 even tells how to connect and set up in the owners manual.
- FURRYe38Jun 11, 2017Guru - Experienced User
I guess 100Mb is good enough.:smileyfrustrated: I presume no streaming with the AVR.
- William10aJun 11, 2017Master
The network only would handling audio data no video data as the amp has 8 hdmi inputs with 3 hdmi outputs for the video part.
