Jim_Bravo
Jul 17, 2019Aspirant
Trouble with Port Forwarding
Hi, I have a Nighthawk X6 router, CDE fiber internet service(no modem). I am attempting to open a few ports to remote connect to a few pieces of factory automation equipment I'm testing at my hou...
- Jul 18, 2019
If your WAN IP address is not a public IP address then you need to call your ISP and help you with this one.
antinode
Jul 17, 2019Guru
> [...] I am attempting to open a few ports [...]
Not a very detailed description of anything. Can you access one of
these devices from a system on your LAN, using the device's LAN IP
address? Using the router's WAN/Internet IP address? (See: ADVANCED >
ADVANCED Home...)
Is your router's WAN/Internet IP address the same as the public IP
address which you're using?
The usual problems with this stuff are:
1. Wrong external IP address (different from the port-forwarding
router's WAN/Internet IP address). (An intermediate NAT router, for
example, could cause this. Or an ISP using carrier-grade NAT to
conserve IPv4 addresses.)
2. Bad port-forwarding rule (wrong port(s), wrong target address --
including a wandering target).
3. Server not listening on the port-forwarding target system.
4. External influences: ISP blocking, other firewalls, ...
Jim_Bravo
antinode wrote:> [...] I am attempting to open a few ports [...]
ADVANCED Home...)
Sorry, this is my first post. I wasn't certain what info would be needed. Also, I've had little success setting up networking equipment in the past. It's always been trouble for me.
There is a fiber interface box of some type outside of the house, which has the ethernet cable coming out of it that connects directly into my router. No other networking equipment is present in the house. The automation equipment I'm having trouble connecting to is directly connected to the router with a couple of cat5e cables.
While connected to the local network: If I type in the LAN IP for any of these devices, I'm taken to the proper home screens. If I type in the internet IP(shown on the ADVANCED HOME screen), I'm forwarded to the home screen for one of the automation devices. If I type the public IP, I get a timed out message.
1: The router is set up to get the Internet IP address "Dynamically from ISP". There is some different IP info in the fields below it, but it's greyed out because I don't have the "Static IP" option selected. The public IP doesn't seem to be changing any time I've checked it. The actual Public IP starts with 162.XXX.XXX.XXX while the IP shown on the ADVANCED HOME screen shows 100.XXX.XXX.XXX.
2: I've contacted the equipment manufacturer (Automation Direct) and am certain I have the equipment set up properly to connect to. I am also pretty confident that I have chosen the proper IP and port to forward for each piece of equipment. I have the router set up as a DHCP server, but I also tried setting static IP's on these devices.
3: I'm not sure how to confirm this. I did read somewhere that the server would have to be listening during port testing. I connected to the equipment on the LAN IP while attempting to connect remotely on a different network/PC and also testing the port on canyouseeme.org. It failed the port test, and also couldn't connect remotely.
4: I haven't considered that the ISP could be a problem, but I'm open to the idea. I don't know what other firewall could be in the way though.
