Knerk
Nov 27, 2021Aspirant
Trouble with set up and having Wifi
I recently received this router from a family member and can not figure how to set it up. I tried plugging an ethernet cord from the current router/modem from Verizon and that didn't work. I tried re...
Knerk
Nov 28, 2021Aspirant
Thanks for the reply. I’ve already tried this and it still cannot connect to the router. I cannot connect to the router through my phones WiFi or through Ethernet on my computer. When connected through Ethernet, it shows no internet and the circle looking icon on the taskbar. Is there any other way?
Nov 28, 2021Guru - Experienced User
You're in a double nat as verizon uses modem/router combo devices.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
to access the netgear, disconnect if from the verizon and reboot the netgear. Then connect a pc/laptop/device to it and try going to its management page without being connected to the verizon device.
