JohnnyWB's avatar
Nov 12, 2015
Trouble with the NightHawk AC1750 WIFI Router
I recently upgraded to the above mentioned WIFI Router and I love it except for one thing.  I can't access the QOS setup for my router and do not understand why.  I can get into the advanced settings...
  • netwrks's avatar
    Nov 12, 2015
    Sounds like the firmware is kind of half loaded. The best thing to do is factory reset the router and config from scratch. After the reset if that does not fix the problem, you shoud reload the firmware again, and also reset to factory and config from scratch.
