JohnnyWB
Nov 12, 2015Tutor
Trouble with the NightHawk AC1750 WIFI Router
I recently upgraded to the above mentioned WIFI Router and I love it except for one thing. I can't access the QOS setup for my router and do not understand why. I can get into the advanced settings...
- Nov 12, 2015
Sounds like the firmware is kind of half loaded. The best thing to do is factory reset the router and config from scratch. After the reset if that does not fix the problem, you shoud reload the firmware again, and also reset to factory and config from scratch.
netwrks
Nov 12, 2015Master
JohnnyWB
Nov 12, 2015Tutor
I would like to thank you so much for helping me with this issue. It did the trick nicely. I was able to access the QOS setup without issue. It's off to bed for me now and tomorrow, I will configure my QOS after I get home from work. If I have any more issues, I will post again.
Thanks again
Johnny
