G_jA67sKi
Aug 10, 2019Follower
trying to connect my Amazon Firestick
My router is 14 years old & I have never had a problem with it. I just purchased the Amazon Firestick. In the process of setting it up the firestick screen asks me to enter my Netgear password. No m...
- Aug 10, 2019
I assume that the firestick is trying to connect to wireless. Password would be what is setup for the wireless SSID connection. It sounds like from your description that you are trying to use the password that you would use to administer the router.
IrvSp
Aug 10, 2019Master
G_jA67sKi wrote:My router is 14 years old & I have never had a problem with it.
What comes to my mind is SECURITY. Wonder if the old router has WPA2-PSK [AES] which might be required? Does it work with NO SECURITY?
Setting up the stick, do you see the 2.4Ghz SSID? I assume you did see it, selected it and you used the SSID p/w, not the router login one.
Do you have connection problems with any other devices?
