Jim7903
Jun 01, 2022Follower
Trying to connect R7000 Nighthawk router to my C7000Router Modem
I’m trying to connect my R7000 Nighthawk router to my C7000 router modem. I connected via a Ethernet cable to the Wan port. I have not been successful. Worked for a sort time then quit. My C7000 ...
Jun 01, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Try putting the C7000 gateway into modem mode.
https://kb.netgear.com/000038798/How-do-I-set-C7100V-into-Passthrough-Bridge-Mode
- michaelkenwardJun 02, 2022Guru - Experienced User
Or put the R7000 into wireless access point mode.
How do I change my NETGEAR router to AP mode after setting it up? | Answer | NETGEAR Support
but beware:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
