Pamelaleok
Aug 05, 2017Aspirant
Trying to connect security cameras to my home
Trying to connect surveillance cameras to my home. When I click on the CM network of the cameras it says internet not available. Could this be happening because of my router? It seems that every time ...
- Aug 06, 2017Thank you so much. I truly appreciate your response. I'll try your suggestions.
Smiles, Pamela
Pamelaleok
Need to be able to view the footage from the camera remotely on my phone from anywhere.
antinode
Aug 05, 2017Guru
> Trying to connect an Eyeclub wifi smart socket camera i got from
> Amazon.
Not a very detailed description of anything. Model number?
> My phone connects to it, but says under the network name... "no
> internet connection" or "no internet available".
I'm not an Android user, and I've never touched an Eyeclub product,
so I know nothing, but if your gizmo is anything like an Orvibo S20
"smart socket", then the no-Internet complaint may be normal.
The idea (with the Orvibo gizmo, at least) is that you temporarily
put the gizmo into a special mode where the gizmo itself becomes a
wireless router, and you connect your phone to it, instead of to your
normal wireless router. In this situation, there is no Internet
connection, because you're connected to the gizmo instead of to your
normal wireless router (and the gizmo's not connected to anything except
your phone). So, nothing to worry about.
Then, in the app, you provide the credentials (SSID, passphrase) for
your normal wireless router, and the app sends these data to the gizmo.
Then the gizmo goes back to its normal mode, and connects to your normal
wireless router (using the credentials which you supplied in the app).
At that point, the gizmo should appear in the "Attached Devices" list
on your normal wireless router's Web page. And the app should also be
able to communicate with the gizmo (through your normal wireless
router), and make the gizmo do whatever the gizmo does.
There are many things which can go wrong with this kind of procedure,
but very few of them have anything to do with your normal wireless
router. More likely, you're not providing the right credentials, or the
app is buggy, or the gizmo is buggy. My guess is that you'll get more
help in some Eyeclub-related forum than you will here.
> from anywhere.
If you can get the gizmo to connect to your normal wireless router,
then that should become possible.
- PamelaleokAug 06, 2017AspirantThank you so much. I truly appreciate your response. I'll try your suggestions.
Smiles, Pamela- PamelaleokAug 06, 2017AspirantIt worked! Just followed your directions! Thank you again!
