BillS29
Aug 26, 2022Aspirant
Trying to create a load-balanced WAN and connect to Netgear R8500
Here's what I have: Working for years ... Netgear cable modem connected to Comast Netgear R8500 connected to cable modem Subnet is 192.168.29 Recently installed T-Mobile Internet Gateway...
- Aug 29, 2022
Problem solved, my configuration was mostly correct. The problem was in testing and moving cables around I think things got squirilly with mac addresses. Rebooting the cable modem after connecting it to the ER605 solved that issue. Then I realized another issue was DNS, the netgear wifi router was now using the ER605 address as its DNS server. I changed DNS in the wifi router to Google's DNS and that part was working. I then attached my T-Mobile to the ER605 and have perfectly performing load balancing. So far at least.
To reiterate for anyone else trying this nonsense, I'm sure this will work with other devices and providers.
Cable Modem <-> ER605 WAN port
T-Mobile Gateway <-> ER606 WAN/LAN1 port
ER605 LAN port <-> Netgear Wifi Router WAN port
On the DR605:
- WAN & WAN/LAN1 configured in WAN mode, Dynamic IP
- LAN created with subnet 192.168.10 (just to eliminate using subnet 192.168.0)
- Load Balancing is enabled
- Application Optimized Routing enabled
- Bandwidth Based Balancing disabled
- Link Backup disabled
- Online Detection configured automatic
On the Netgear Wifi Router, set DNS servers to 8.8.8.8, 8.8.4.4
Working perfectly
Aug 26, 2022Guru - Experienced User
I don't believe that will work. You don't have a "Load Balancing" supporting router. Most home class routers don't have this support. Mostly seen in enterprise environments. Best then would be to configure AP mode on the R8500 and connect it to the new VPN router that could connect to the ComCast modem.
- BillS29Aug 26, 2022Aspirant
Thanks, so connect both internet gateways (cable modem and t-mobile gateway) to the Tp-link and then tp-link to the R8500 set up as an access point? Does the ER605 (VPN router) subnet matter in this configuration?
Also, the ER605 does indeed support both bandwidth load balancing or link-down fail-over supposedly. I can't attest to it since I've not gotten that far.
Thanks so much for responding.
- FURRYe38Aug 26, 2022Guru - Experienced User
Yes.
Something to contact the mfr of that device and see since is there product.
- BillS29Aug 29, 2022Aspirant
On the DR605:
Working perfectly
