MRSTRUZ
Oct 08, 2018Aspirant
Trying to go back to previous version of firmware
After upgrading to the latest firmware i am having major troubles with my router/modem and i want to return to the version before.
i have downloaded the firmware version i want and unzipped the fil...
- Oct 08, 2018
Are you sure you have a D7000 and NOT a D7000 V2? The V2 requires a .CHK file.
See https://www.netgear.com/support/product/D7000v2.aspx#Firmware%20Version%201.0.0.52 for firmware if you do have a V2 version of the D7000.
IrvSp
Oct 08, 2018Master
- MRSTRUZOct 08, 2018AspirantThank you. The box only states it’s a D7000 but after logging into the router it is in fact a v2
