SmittyTuff
Nov 14, 2020Follower
Trying to make a server for a game (SCP Secret laboratory)
After i put in this information for the port forwarding, my friend is unable to join because of the error "Specified host is not avaible". And after about an hour of troubleshooting, nothing changed ...
antinode
Nov 19, 2020Guru
Where, exactly, did you "put in this information for the port
forwarding"? Hint: "Block Services" and "Port Forwarding" are spelled
differently for a reason.
> [...] in the video i used, [...]
Thanks for not including a link. I hate watching low-quality
"instructional" movies, especially ones which apparently didn't do the
job.
> [...] i dont think i could find what i was looking for. [...]
I think that you're right. Looking in the right place might help
some.
> Model: R6700|Nighthawk AC1750 Smart WiFi Router
Is that accurate? Not an R6700v2 or R6700v3? Look for "Model" on
the product label. Firmware version? Connected to what?
> [...] I'm trying to get this done quickly.
One ready, but widely neglected, resource:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Port Forwarding".
If you have trouble _after_ you find the right section of the
settings, then you might get some hints from:
