msg2000
Sep 13, 2023Aspirant
trying to reset my wifi name and password on nighthawk r7000
All I know is resetting a password should be easier than this. I bought this router in 2018 and never changed the name and password that came with it. Now I would like to. I have the nighthawk app...
Kitsap
Sep 13, 2023Master
msg2000 wrote:All I know is resetting a password should be easier than this.
I have the nighthawk app on my phone but its not working out. Wifi connection issues it says when I try to submit the name and password reset.
I called Netgear and spoke with someone who in the end sent me this email.
Good Day!
I would recommend the following NETGEAR articles that will provide you helpful information and troubleshooting steps.
Article 1:
URL : https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Article 2:
URL: https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Every time I try the following url...
routerlogin.net. I get a page that has product photos and that basically tells me to download the nighthawk app. The links sent above I have followed and still can not see a page online that allows me to change it. Ive tried dumoing cache and tried Chrome and Safari. Still I see the same page without the controls to be able to renter a new name and password for the wifi.
Can anyone help?
The Nighthawk mobile application is of very limited usefulness, and none at all in this case as you have found.
A couple of options are available. If you have a computer you can connect to your router via an Ethernet cable, that is your first choice. If not, a Wi-Fi connection should work.
You will need to find the IP address of your router. Here is a reference document. Avoid all of the recommendations to use the mobile application. You will need to dig down to the second or third option.
https://kb.netgear.com/27199/I-can-t-access-my-router-what-do-I-do?cid=wmt_netgear_organic
Once you find the IP address of your router, another option is to use a mobile device with a web browser. You will have to be connected to your local Wi-Fi for this to work.
