Axic10
Aug 05, 2016Aspirant
Trying to set up blocking of steam and other sites without the person knowing Nighthawk R7000 Router
I have a 21 year old step son who has developmental disabilities and freaks out if we flat out block his internet in order to get him out of his room. I've tried to block the ports for Steam, but I d...
- Retired_MemberAug 05, 2016
resevations is in LAN setup............blocking is done by adding rule from pull down menu....... both are simple to do ....
Retired_Member
Aug 05, 2016Try blocking HTTPS use address reservations for his device so it gets same ip
Axic10
I tried to so some searching on this, but I'm not sure if I'm following it. Are there any guides on doing this? Thanks for your help!
- Axic10Aug 05, 2016Aspirant
Disregard, the picture didn't show up originally. I'll test this out now.
I added one of my devices to test this out under LAN setup. I don't see anything about a rule under LAN Setup, where can I find that? Thank you again, I apologize in advance if I'm being a pain.
This seems to work when testing it out on my computer, so I rolled it out to my step son's computer using the method you suggested. Thanks!
I gave up on trying to make the picture bigger, two different menus sorry... lan setup and security block services
