leddie78
Jan 06, 2022Aspirant
Trying to update Firmware on Router
I am trying to update firmware on my router, using the Nighthawk app on my phone. I tap on the icon, tap check for updates, and get the message "There was a problem checking firmware update", then ei...
Jan 06, 2022Guru - Experienced User
I recommend following this if you need to update FW on the router:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
What model router do you have?
