lulup
Apr 13, 2018Tutor
"Turn off wireless signal by schedule" does not turn wifi BACK ON
After enabling "Turn off wireless signal by schedule", WIFI does not turn wifi BACK ON at the scheduled time. My time zone is correct. I have tried this with both 2.4Hz and 5Hz. same behavior - wifi ...
- Jun 20, 2018
Hi tooreck,
For R8000, firmware 1.0.4.18 is the latest version. Have you tried resetting the router?
Blanca
Community Team
schumaku
Apr 13, 2018Guru - Experienced User
Firmware version?
Factory reset done following some major updates, and manually reconfigured the R7000 again?
lulup
Apr 13, 2018Tutor
V1.0.9.26_10.2.31 - i believe that's the latest.
I'll try the factory reset later today and post my results.
Thanks!
- lulupApr 13, 2018Tutor
OK, I did a factory reset and set it all back up (including confirming that firmware is current and the schedules are enabled) and tested it. Now, instead of it not coming back online after the period is over, it doesn't turn off at all. Any ideas?
Thanks.
