lulup
Apr 13, 2018Tutor
"Turn off wireless signal by schedule" does not turn wifi BACK ON
After enabling "Turn off wireless signal by schedule", WIFI does not turn wifi BACK ON at the scheduled time. My time zone is correct. I have tried this with both 2.4Hz and 5Hz. same behavior - wifi ...
- Jun 20, 2018
Hi tooreck,
For R8000, firmware 1.0.4.18 is the latest version. Have you tried resetting the router?
Blanca
Community Team
lulup
Apr 13, 2018Tutor
V1.0.9.26_10.2.31 - i believe that's the latest.
I'll try the factory reset later today and post my results.
Thanks!
lulup
Apr 13, 2018Tutor
OK, I did a factory reset and set it all back up (including confirming that firmware is current and the schedules are enabled) and tested it. Now, instead of it not coming back online after the period is over, it doesn't turn off at all. Any ideas?
Thanks.
- lulupApr 19, 2018Tutor
Anyone have any ideas? I know there are some smart people in this forum!
- schumakuApr 19, 2018Guru - Experienced User
Disable the "Turn off wireless signal by schedule" as long as the wireless is enabled - and pry it will be fixed one day. (Sorry, could not resist...).
Hilarious.
How about this. If there's anyone out there willing to run a 5 minute test for me, try enabling this feature and tell me what your results are! Be sure to check the time zone settings, then enable the wifi to turn off at the next available time, and back on a half hour (or whatever) later. Did it turn off? Did it turn itself back on? Did you find some weird behavior like choosing the half hour actually breaks it, etc. If I can't get this working, I'm going to buy another device that will shut off the power to my router at night (decreasing my exposure to EMFs) and who needs one more device!
