lulup
Apr 13, 2018Tutor
"Turn off wireless signal by schedule" does not turn wifi BACK ON
After enabling "Turn off wireless signal by schedule", WIFI does not turn wifi BACK ON at the scheduled time. My time zone is correct. I have tried this with both 2.4Hz and 5Hz. same behavior - wifi ...
- Jun 20, 2018
Hi tooreck,
For R8000, firmware 1.0.4.18 is the latest version. Have you tried resetting the router?
Blanca
Community Team
schumaku
Apr 19, 2018Guru - Experienced User
Disable the "Turn off wireless signal by schedule" as long as the wireless is enabled - and pry it will be fixed one day. (Sorry, could not resist...).
lulup
Apr 19, 2018Tutor
Hilarious.
How about this. If there's anyone out there willing to run a 5 minute test for me, try enabling this feature and tell me what your results are! Be sure to check the time zone settings, then enable the wifi to turn off at the next available time, and back on a half hour (or whatever) later. Did it turn off? Did it turn itself back on? Did you find some weird behavior like choosing the half hour actually breaks it, etc. If I can't get this working, I'm going to buy another device that will shut off the power to my router at night (decreasing my exposure to EMFs) and who needs one more device!
- schumakuApr 19, 2018Guru - Experienced User
Can only speak for the R9000 here - Central European Time, DST enabled. 05:00pm (WT* AM/PM here?) the WLAN went down, and 05:30pm the WLAN cambe back. A few related oddites aorund the WPS LED, but this is beyond the scope here as I'm operating a Beta firmware 1.0.3.16, but reported to Netgear.
Now somebody with an R7000 please...
