lulup
Apr 13, 2018Tutor
"Turn off wireless signal by schedule" does not turn wifi BACK ON
After enabling "Turn off wireless signal by schedule", WIFI does not turn wifi BACK ON at the scheduled time. My time zone is correct. I have tried this with both 2.4Hz and 5Hz. same behavior - wifi ...
- Jun 20, 2018
Hi tooreck,
For R8000, firmware 1.0.4.18 is the latest version. Have you tried resetting the router?
Blanca
Community Team
schumaku
Apr 19, 2018Guru - Experienced User
Can only speak for the R9000 here - Central European Time, DST enabled. 05:00pm (WT* AM/PM here?) the WLAN went down, and 05:30pm the WLAN cambe back. A few related oddites aorund the WPS LED, but this is beyond the scope here as I'm operating a Beta firmware 1.0.3.16, but reported to Netgear.
Now somebody with an R7000 please...
lulup
Apr 19, 2018Tutor
Thank you for taking the time to do that!
- tooreckJun 02, 2018Guide
I was able to do it only be reversing the firmware toan older version. New update messed things up. See here:
- lulupJun 07, 2018Tutor
Thanks tooreck! very helpful to know others can't do it either. I got frustrated and bought a device that with a remote control, I just cut the power to the router. I don't love the solution because I feel like it's probably not good for the router to just be shut off that way every day but I got tired of f*%&ing with the router settings to try and make that work.
- tooreckJun 07, 2018Guide
Have you tried reversing firmware to an older version? It really worked in my case and now the scheduling program is just humming and running smoothly.
- lulupJun 08, 2018Tutor
No, I haven't tried that. I'm not willing to sacrifice the protection against Krack etc that the new firmware version supplied. I'll just use my crude solution until Netgear fixes that feature. Thanks!
