lulup
Apr 13, 2018Tutor
"Turn off wireless signal by schedule" does not turn wifi BACK ON
After enabling "Turn off wireless signal by schedule", WIFI does not turn wifi BACK ON at the scheduled time. My time zone is correct. I have tried this with both 2.4Hz and 5Hz. same behavior - wifi ...
- Jun 20, 2018
Hi tooreck,
For R8000, firmware 1.0.4.18 is the latest version. Have you tried resetting the router?
Blanca
Community Team
tooreck
Jun 20, 2018Guide
Hi Blanca,
So, what about my model (R8000|Nighthawk X6 AC3200)? For how long am I stuck with 1.0.4.18_10.1.49 update and that same bug?
Thanks,
Blanca_O
Jun 20, 2018NETGEAR Employee Retired
Hi tooreck,
Blanca
Community Team
- Blanca_OJun 24, 2018NETGEAR Employee Retired
Hi tooreck,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
- tooreckJun 30, 2018Guide
Blanca,
I was not having access to my account to reply till now.
Of course the reset doesn't help. The reset is being done automatically after time off is set up, but I also done it manually. No difference. The firmware has a bug - it'd be great if Netgear admitted it and did something about it. Have you reported this is to the project team? Have they reproduced the issue? Is Netgear even serious about it?
Thanks...
Hi Blanca,
Yes, I have tried resetting the router multiple times.
Please...
It did not work, neither did time zones because they were set correctly. This is the firmware issue. Period.
