lulup
Apr 13, 2018Tutor
"Turn off wireless signal by schedule" does not turn wifi BACK ON
After enabling "Turn off wireless signal by schedule", WIFI does not turn wifi BACK ON at the scheduled time. My time zone is correct. I have tried this with both 2.4Hz and 5Hz. same behavior - wifi ...
- Jun 20, 2018
Hi tooreck,
For R8000, firmware 1.0.4.18 is the latest version. Have you tried resetting the router?
Blanca
Community Team
XB
Jun 25, 2018Initiate
Hello, I'm not sure if this was answered in this thread. I had the same issue. It drove me nuts.
I discovered it was in the Time Zone settings listed under the the Advanced tab, Security and Schedule (odd location). The bottom shows your time zone and below that the option to "Automatically adjust for daylight savings time". My config did not have the selected. At the very bottom it shows the actual date/time it is using.
I made the adjustment before I noticed the status line. But it is now corrected and making this adjustment.
I hope this helps anyone who needs it.
Blanca_O
Jun 25, 2018NETGEAR Employee Retired
Hi XB,
Glad to hear that you got it working.
Blanca
Community Team
