lulup
Apr 13, 2018Tutor
"Turn off wireless signal by schedule" does not turn wifi BACK ON
After enabling "Turn off wireless signal by schedule", WIFI does not turn wifi BACK ON at the scheduled time. My time zone is correct. I have tried this with both 2.4Hz and 5Hz. same behavior - wifi ...
- Jun 20, 2018
Hi tooreck,
For R8000, firmware 1.0.4.18 is the latest version. Have you tried resetting the router?
Blanca
Community Team
lulup
Jul 02, 2018Tutor
UPDATE! YOU GUYS I GOT IT WORKING!
I had gotten around the problem by plugging the damn thing into a wall unit that I remote controlled and cut the power to every night before bed. That was ok but I watched this forum for better answers. found on! or really two!
One of you mentioned that the 'adjust for daylight savings time' should be checked. Did that and it was NOT checked. So I checked the box.
And I did another firmware update. (I had done this before but there was another upgrade)
One of those fixed it!
I know the daylight savings time setting is critical but Netgear may also have released a fix in the latest firmware.
Yay!
Blanca_O
Jul 02, 2018NETGEAR Employee Retired
Hi lulup,
Thank you for your feedback. Glad that it's working now.
Blanca
Community Team
- dehavenJul 19, 2018Tutor
I own a Nighthawk X6 R8000. THIS PROBLEM IS N-O-T FIXED. There are actually three issues here:
1. BIZZARE INTERFACE: The timezone setting for the router is hidden in the blocking scheduler. But even worse than this, the router scheduler is so hidden that one may think the blocking schedule is the router scheduler. Both should be under Administration. What is advncedabout scheduling your router to turn off so that you are not blasted with RF while trying to sleep? This is a MASSIVE interfae design issue. If any at NETGEAR is listening, I am a retired programmer who used to earn a lot of money solving interface design FAILURES such as this. MOVE IT!
2. TOTAL **bleep**DOWN. The router scheduler needs to AT THE VERY LEAST have a total software shutdown option, not just for RF. The router should be compeltely turned off by the scheduler.
3. MASSIVE BUG. How the heck does mature software like this hzve such a massive bug? The "Turn off wireless signal by schedule" unchecks iself when applying the update. I even went so far as to split my off time of 11:00 PM to 7:00 AM into two entries thinking the span across a day may be confusig the software.
I am not being critical just to hea myself speak. The truth is that when a company as large as Netgear gets this sloppy, it is indicative of problems so serious that I would divest myself of any of their stock. I challenge anyone in that company to explain to me why, even as a retired computer programmer, I must search for timezone setting and a router scheduler so that my children may sleep without 5 Ghz RF signals in the night, when they are completely unnecessary, at least in my house? Anyone? Can anyone excuse this level of sloppiness?
Just do it! Npo, I mean, Just fix it!
Corrected version....
1. BIZARRE INTERFACE: The timezone setting for the router is hidden in the blocking scheduler. But even worse than this, the router scheduler is so hidden that one may think the blocking schedule IS the router scheduler. Both should be under Administration. What is advanced about scheduling your router to turn off so that you are not blasted with RF while trying to sleep? This is a MASSIVE interface design issue. If any at NETGEAR is listening, I am a retired programmer who used to earn a lot of money solving interface design FAILURES such as this. MOVE IT!
2. TOTAL SHUTDOWN. The router scheduler needs to AT THE VERY LEAST have a total software shutdown option, not just for RF. The router should be completely turned off by the scheduler.
3. MASSIVE BUG. How the heck does mature software like this have such a massive bug? The "Turn off wireless signal by schedule" unchecks itself when applying the update. I even went so far as to split my off time of 11:00 PM to 7:00 AM into two entries thinking the span across a day may be confusing the software.
I am not being critical just to hear myself speak. The truth is that when a company as large as Netgear gets this sloppy, it is indicative of problems so serious that I would divest myself of any of their stock. I challenge anyone in that company to explain to me why, even as a retired computer programmer, I must search for a timezone setting and a router scheduler so that my children may sleep without 5 Ghz RF signals in the night, when they are completely unnecessary, at least in my house? Anyone? Can anyone excuse this level of sloppiness?
Just do it! No, I mean, Just fix it!- schumakuJul 20, 2018Guru - Experienced User
Reads very similar to my repeated complaints on the very same issue. Can't agree more. Some community members used to talk about a new UI for the Nighthawk models - but I'm concerned that would be lipstick on a pig: Unreliable dev kits from the SoC makers (with decades old Kernels, tools, and utilities), paired with some wacky vendor standardised config APIs and config storage without redundancy, without consistency testing, ... wont be any better - unless there is a complete bottom-up revision.
Not sure about your concern. Mobile devices, tablets, and other IoT change to 4G (and soon 5G) if they loose the WiFi connection. Many tasks and jobs are run off-hours (There is another life of a mainframe while there are no interactive sessions, right? That's why the industry is still selling software schedulers for various environments.) And the next mobile tower, the next digital TV tower, the next digital radio, and where these remain the next FM transmitter, the near airport radar, the weather radar can't be scheduled. And all of these come in with much more energy than the WiFi.
Doing this would require a much more advanced (read: expensive) hardware design. The physical (DC) power button has to go for example, or must be substituted by a software/logic driven button. A complete shutdown should lead to a power-off, or low-power sleep mode. Part of the system has to remain powered to run a clock and power-up as per the schedule. This does add (depending on the design) problems with regulatory requirements for systems in standby mode (like the European EUP, max 0.5W) perfectly feasible for such a small system of course.
Taking this that the wireless schedule does "normally" work on your R8000? It does for me on the R9000 for a while, certainly since the 1.0.4.x firmware. If this "Turn off wireless signal by schedule" unchecks itself when applying the update." is the "only" problem remaining, well, ... it's just yet another (new or old) bug. Indeed, Netgear does not make it easy to run over some obscure sub-menu sections (I still can't remember after a long time using these devices) to review the settings.
- tooreckJul 19, 2018Guide
Thanks for replying and confirming this problem. I wonder if Blanca will reply to this one, or she'll only kudo some easy not-working solutions such as "rebooted my router"... She, nor any other Netgear person, will not admit they have a massive issue with this.
Dear Blanca - the issue remains NOT SOLVED!
Dear Blanca - the issue remains NOT SOLVED! See dehaven's post - very informative.
How long will you and Netgear just sit there and look the other direction, pretending you have no issue?
Please do something about it!
The OP and the post marked as solved is related to the R7000.
Yes - however leaving the poor usability away, he does refer to a problem that the schedule activation is not retained over the firmware update.
Not sure the Netgear community people have enough power. I fear the product managers, the engineering, and the developers are living on a different planet and are working on wrong and incomplete KPIs.
