NorthSideBound
Jan 05, 2021Aspirant
Turned on Wireless Access Point and can no longer access 192.168.1.1 interface
So I have been struggling with fixing constant lag spikes through all my gaming experiences. I searched every possible solution to try and fix it and managed to actually find a solution by turning...
michaelkenward
Jan 06, 2021Guru - Experienced User
Can you still see the wifi from the R6400 in AP mode? If so, then your main router, or some app or other that looks at local wifi SSIDs, should have a record of the current IP address of your AP. I often look at the Network Map in the desktop genie for Windows.
If you feed that IP address into a browser it should take you to the browser graphical user interface (GUI) of the R6400. It will be something along the lines of 192.168.1.XX if your router is on 192.168.1.1.
If you are lucky, in the genie it can be a simple case of clicking the IP address for the device.
antinode
Jan 06, 2021Guru
> [...] if your router is on 192.168.1.1.
> [.,.] can no longer access 192.168.1.1 interface
Think about it.
