BlnBiker
Apr 08, 2023Tutor
two R7450 have different speeds
I have 2 identical R7450 wifi radios that if a device connects to one or the other it gets different speeds On one the speed is only about 1/3 than on the other radio any idea anyone what might b...
BlnBiker
Apr 08, 2023Tutor
fimware on both is V1.2.0.92 _1.0.1
The modem is a Spectrum EU2251
the router is a TP-Link ER 605 V2
both nighthawks are set to "AP" mode (router disabled)
speed test are done with the same device on the same network with the same test site (Ookla)
Apr 09, 2023Guru - Experienced User
are you disabling smart connect so you can specify what band to connect to?
To many times I've seen smart connect on and people connecting to the 2.4ghz when its a slower network.
Also, what channels are you using because you're running 3x routers. The 2x R7450's and the one other.
Could be you're causing interference on one of them thats slowing things down too.
