Astamanyana
Apr 19, 2018Aspirant
Two R9000 Wifi Can't resolve IP
Hi there! I have a bad habit of consistently upgrading my wifi network, and, I have a main R9000 downstairs with a wifi AP R9000 upstairs. The router downstairs has the wifi turned off, but I would like both to work at the same time and with the same SSID (the wifi doesn't extend downstairs very well at all). Both are upgraded to the latest firmware (same version), to the extent that's relevant.
When I turn the downstairs wifi on and walk downstairs, it works perfectly. As soon as I walk back upstairs, it works terribly (assuming it's still connected to the router downstairs for some reason). So, I disconnect and reconnect. That's when I get the 'can't resolve IP' error. What am I doing wrong here? Thank you for your help, in advance!
Best regards,
Asta
For whatever reason, updating the firmware on both of the R9000s and setting them to 'smart connect' (one SSID for the 2.4 & 5 channels) seems to work. I can walk around the house, connect and reconnect, without the unable to resolve IP issue. Effectively, it works.
The DHCP is the main R9000 I have downstairs.
Modem -> R9000 Downstairs -> 24 Port Gig switch -> all other devices (including AP R9000). Everything is connected via Cat7
Now, I'm wondering how to ensure that I connect to the R9000 that will provide the best connection. This is just me nitpicking, but when I'm downstairs my bandwidth is less than 25% of what it is upstairs (even when right next to the downstairs router that's connected directly to the modem).
I habitually upgrade my network with new netgear devices, cabling, etc... so I'm moving on to that problem next if anyone has any insight!
Hi Asta,
By rule of thumb - you have done nothing wrong.
Same network names set, probably Smart Connect enabled on the router as well as on the AP (if it is available there), same security keys.The R9000 AP connected using the WAN port to a LAN port of the R9000 router.
I have just some single R9000 in use, no second R9000 to test AP mode ... just yet another user.
There might be some interesting insight in the router and the AP system logs. Can you (copy-paste) or as an attachment (text file) the content of the log on both R9000 right after the "roaming" resp. re-association of the mobile device went wrong (resp. there was no IP issued by DHCP, or whatever)?
One more detail for the R9000 product engineer to look into I guess.-Kurt
- AstamanyanaAspirant
Definitely will do so tonight! However, I guess the logs were cleared when I updated the firmware.So, I can't get the data from when I tried it last.
- xnsysLuminary
Where is your DHCP server?
Astamanyana wrote:Now, I'm wondering how to ensure that I connect to the R9000 that will provide the best connection. This is just me nitpicking, but when I'm downstairs my bandwidth is less than 25% of what it is upstairs (even when right next to the downstairs router that's connected directly to the modem).
Explained several times, last one in https://community.netgear.com/t5/Orbi/5g-vs-2-4g/m-p/1552427 ... a wireless client STA can roam much faster between multiple BSSIDs (virtual radio MAC) serving the same ESSID (network name). Every STA is maintaining a weighted list of all BSSIDs in the range, and is "constantly" (typically in a timed loop) evaluating the environment again. If there is an AP STA where things look better, the client STA will roam over to the better BSSID. The bad impression you had before was caused by different ESSID (network names). If a client STA is connected, much more (lower signal, interference, ...) is required to make the client change to a different ESSID network.
There is a lot of room - copper goes up to 10 GbE nowadays, Fiber up to 400 GbE - promised, you have always the best connection to your switch infrastructure. Next WiFi generation is virtually awaiting behind the door, late 2018, early 2019. But here again, as already with 802.11ac and 802.11ac wave 2 (MU-MIMO) the focus is on smooth interoperability, not towards egoistic single user data rates for a single client.
