Retired_Member
Jan 16, 2022Two routers, one network - unstable
I'm not the first to have an issue here, but I can't find a solution to my problem. I've set up two Nighthawk Rax50. Same SSID and password. Second router has DHCP disabled and has IP... 1.2 First ...
- Retired_MemberJan 18, 2022Turned out AP worked, and what didn't work at first with AP was fixed with a restart of the router and the unstable equipment.
Jan 17, 2022Guru - Experienced User
You should have thte 2nd one set it access point mode. If you have a certain IP address you'd like it on, you can reserve that address in the lan setup for IP reservation.
You should also have them set on different wireless channels for both 2.4ghz and 5ghz to prevent interference.
With a mesh system they use the same channels but when using a non-mesh system with access points, they should be seperated out.
