mctalks's avatar
Mar 11, 2022
Unable to access advanced router settings
For some reason, I am unable to access the advanced settings at routerlogin.net. It shows as an active link, but won't open as it did initially when I first set up my router.
Also, the phone app is set to anywhere access and I can't turn it off from my phone.
1 Reply
  • plemans's avatar
    Have you tried different web browsers or pc?
    What router do you have ?
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
