itm60
Jun 05, 2022Follower
Unable to access LAN resources via VPN on X45 R7800
I've enabled the VPN service on my X45 R7800, and selected "All sites on the internet & home network" as the access option for clients.
I've downloaded the Android config package and installed it on my Moto G 5G Plus. It connects to the VPN, but gets assigned an IP address of 192.168.2.*, and can't access any of the resources on my LAN (which are in the range 192.168.1.*).
Is there any way that I can configure the VPN to give clients access to resources on the LAN?
- KitsapMaster
First suggestion would be to log in to your router and go to Advanced -> Setup -> LAN Setup and reserve an unused address in the range 192.168.1.* for your phone based on phone MAC address. You may have to connect to your Wi-Fi at home with your phone to determine the specific MAC address for the band you are using (2.4 GHz, 5 GHz, etc.)
- itmTutor
Thanks for the suggestion. I set up a reservation of 192.168.1.155 for my phone's MAC address, but it got ignored when I connected to the VPN - it got allocated 192.168.2.2 again
- KitsapMaster
In the LAN setup section you choose the IP address for the router itself and also the range of addresses to be assigned via DHCP.
I set 10.0.0.1 for my router and the start/stop range as 10.0.0.100 - 10.0.0.149 for my DHCP. I am using TCP for the TUN mode service type. I have full access to all LAN resources (NAS, IP cameras, etc.)
