chrisxyz11
Jul 13, 2022Aspirant
Unable to access Nighthawk Admin from WWW
I have a Nighthawk WIfi Router that is sitting behind a Spectrum Arris TM1602 broadband modem. I am able to access the browser based admin from within my lan but wish to access the admin from out...
Jul 13, 2022Guru - Experienced User
So what model# is this router? R or RAX?
Does HTTP or HTTPS and 192.168.1.1 work in any browser?
Try a different PC or laptop to compare?
If all else fails, a factory reset maybe needed.
- chrisxyz11Jul 13, 2022Aspirant
Its an MR50.
10.0.0.1 is the routers IP address from my LAN. Using both Chrome and safari I can login. I have tried both a mac and an iphone to test from an external perspective. As mentioned externally I am able to access other services I did port forwarding with (one at least has a web UI and functions fine, other forwards include SSH and MOSH and both those work fine too.
Thanks
C- FURRYe38Jul 14, 2022Guru - Experienced User
I believe NG removed any kind of remote management access from all routers. Only mobile apps like Nighthawk app can access routers from the WAN side.
Is this a mobile cell phone router? MR50 is not a valid model#.
