kichu-roy's avatar
kichu-roy
Unable to add repeater to existing Netgear router
I tried by simply adding the Wifi SSID to repeater router(Universal repeater mode is ON). I use Netgear_r6120 as my primary router. The repeater I added is unable to provide internet to devices connected to it. Is there any settings that I have to change in my primary router?? Help!!
  • plemans's avatar
    What modem/gateway do you have?
    Your router is the R6120? What firmware is on it?
    What universal repeater are you adding?
    How are you adding it?
    • kichu-roy's avatar
      kichu-roy
      Router : R6220
      Router Firmware Version
      V1.1.0.106_1.0.1
      I'm trying to use my old Tenda router(N301) as Wifi Extender(Not in WISP or AP mode). As I came to know the Wireless repeating feature not available in R6120. So I just changed to R6220. Wifi SSID(2.5 & 5Ghz) name is not even showing in the Tenda router while trying to connect normally.
      My requirement is to extend Wifi without any physical connections.
      Thanks.
      • plemans's avatar
        I'd be checking with tenda on how to setup their devices. I've had one before and it was pretty sketchy
