chris2969's avatar
chris2969
Unable to change Device Name (or rename) using Access Control - R6900P
I have been trying to fix some device names under access control in my R6900P router. It takes the change, I apply it on the edit screen as well as in the "allowed devices" screen but then when I refresh the screen it remains as it was before my edit.
Please suggest a way to make the name change remain in place.
Note in some cases the name is
whereas in other cases it has an alpha numeric string.
Thanks
Chris
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi @chris2969, welcome to the community! May we know if you are still experiencing the issue?
    Dexter
    NETGEAR Team
    • chris2969's avatar
      chris2969
      Unfortunately the issue is still there - unable to rename devices.
