Draehawk
Dec 28, 2015Tutor
Unable to connect to 5GHz - (Nighthawk x6 AC3200 (r8000))
I've recently bought a Nighthawk x6 AC3200 and everything is working all right, except that my computer can't seem to detect the 5 GHz bands. On my computer, I have a PCE-N53 PCI-E Adapter Dual-ban...
- Dec 28, 2015
I tried your solution, but none of the channels displayed the 5 GHz band.
I searched online for related issues with the PCE-N53 and found a thread that solved my issue.
Here's the link if it may help someone else:
http://www.tomshardware.com/answers/id-1693495/asus-usb-n53-detect-5ghz.html#12103237
I had to download this driver from Mediatek, for some reason:
http://www.mediatek.com/en/downloads1/downloads/pcimpcicbrt2860rt2760rt2890/
Thanks for your help TheEther!
Draehawk
Dec 28, 2015Tutor
On the PCE-N53 box, it is written:
"Operating Frquency
2.4GHz / 2.4 - 2.483GHz
5GHz / 5.1 - 5.8 GHz"
The router is currently set on channel 44 (by default, it can be set to 36, 40, 44 or 48) for the 5GHz-1, and channel 153 (by default, it can be set to 149, 153, 157 or 161) for the 5GHz-2.
Both are set to the "Up to 1300 Mbps" mode, but the network card has a data rate of up to 300 Mbps.
Which channel should I put instead?
Does my issue have anything to do with the driver's "Country Region (5 GHz)" setting (currently set at #0 (36 - 64, 149 - 165))?
TheEther
Dec 28, 2015Guru
It may sound flippant, but try every channel until you find one that works.
Also, make sure the driver is set to use 5 GHz. Sometimes, the setting won't be obvious. It could be obscure, like setting the wireless mode to either 802.11b/g/n or 802.11a/b/g/n. The latter choice includes 802.11a, which operates at 5 GHz and would be the more correct choice.
- DraehawkDec 28, 2015Tutor
