Draehawk
Dec 28, 2015Tutor
Unable to connect to 5GHz - (Nighthawk x6 AC3200 (r8000))
I've recently bought a Nighthawk x6 AC3200 and everything is working all right, except that my computer can't seem to detect the 5 GHz bands. On my computer, I have a PCE-N53 PCI-E Adapter Dual-ban...
- Dec 28, 2015
I tried your solution, but none of the channels displayed the 5 GHz band.
I searched online for related issues with the PCE-N53 and found a thread that solved my issue.
Here's the link if it may help someone else:
http://www.tomshardware.com/answers/id-1693495/asus-usb-n53-detect-5ghz.html#12103237
I had to download this driver from Mediatek, for some reason:
http://www.mediatek.com/en/downloads1/downloads/pcimpcicbrt2860rt2760rt2890/
Thanks for your help TheEther!
TheEther
Dec 28, 2015Guru
It may sound flippant, but try every channel until you find one that works.
Also, make sure the driver is set to use 5 GHz. Sometimes, the setting won't be obvious. It could be obscure, like setting the wireless mode to either 802.11b/g/n or 802.11a/b/g/n. The latter choice includes 802.11a, which operates at 5 GHz and would be the more correct choice.
Draehawk
Dec 28, 2015Tutor
