Jim_Elma's avatar
Apr 29, 2018
Unable to connect to other connected devices
I have 2 PC's connected to my router. The first is my desktop which is wired via Ethernet. The 2nd is my Laptop which is connected via WiFi.
Recently, neither device can see the other on the network.
I'm unaware as to how this happened.
With both devices powered up and running on the network. I went into the router's web based network admin settings to view what the "attached devices" said for each of these PC's. Each showed their own PC device, 3 cell phones, one printer and one Xbox device.
The Desktop did not show the Laptop device and the Laptop did not show the Desktop device.
Can you advise how I can resolve this ?
  • IrvSp's avatar
    IrvSp
    Apr 29, 2018
    Jim_Elma, I guess some examples might be in order...
    NEW VIEW (run from a CMD prompt):
    C:\>net view
    Server Name            Remark
    \\IRV8700              Irv's 8700
    \\LARAINE-XPS8500      Laraine's XPS8500
    \\READYSHARE           readyshare
    The command completed successfully.
    As you can see, although I also have an Amazon Echo and FireTV Stick, as well as 2 iPad's on the LAN, only the PC's (mine is wired, wife's is wireless) and the USB drive on the router have 'shares' on the SERVER NAME.
    One can do a NET VIEW on any SERVER NAME and see the shares available, like:
    C:\>net view \\laraine-xps8500
    Shared resources at \\laraine-xps8500
    Laraine's XPS8500
    Share name  Type  Used as  Comment
    C_disk      Disk
    D_drive     Disk
    E_drive     Disk
    Since I know her IP Address I can also get to it that way (bypasses SMB1 by the way):
    C:\>net view \\192.168.1.40
    Shared resources at \\192.168.1.40
    Laraine's XPS8500
    C_disk      Disk
    D_drive     Disk
    E_drive     Disk
    Now the USB drive on the router using the Server name and IP Address:
    C:\>net view \\readyshare
    Shared resources at \\readyshare
    readyshare
    Movies       Disk           read:all-no password;write:all-no password
    USB_Storage  Disk           read:admin;write:admin
    C:\>net view \\192.168.1.1
    Shared resources at \\192.168.1.1
    readyshare
     You can use the DIR command to see what is the Server's share, like :
    C:\>dir \\readyshare\usb_storage
     Volume in drive \\readyshare\usb_storage is USB_Storage
     Volume Serial Number is 8A4E-F8FB
     Directory of \\readyshare\usb_storage
    04/29/2018  12:14 PM    <DIR>          .
    01/01/2015  04:00 AM    <DIR>          ..
    05/10/2014  01:54 PM    <DIR>          $RECYCLE.BIN
    11/10/2017  09:25 PM       423,489,144 Audio_Driver_PKGMR_WN32_6.0.1.7564_A01.EX
    E
    05/30/2013  07:15 PM    <DIR>          AUTORUN
    07/23/2009  02:07 PM                28 AUTORUN.INF
    11/14/2016  04:00 PM    <DIR>          netgear_downloader
    03/27/2018  06:08 PM                48 norton_2018.txt
    10/30/2016  12:42 PM    <DIR>          Pictures
    08/18/2017  01:25 PM    <DIR>          share
    04/29/2018  10:49 AM    <DIR>          System Volume Information
    04/29/2018  10:47 AM    <DIR>          W10_image
    04/15/2005  08:48 AM             6,722 WDLOGO.ICO
    04/29/2018  10:47 AM    <DIR>          WS_HOLD
                   4 File(s)    423,495,942 bytes
                  10 Dir(s)  417,499,398,144 bytes free
    You can substitute IP Address for the Server name above too.
    Now the NET USE command:
    C:\>net use t: \\readyshare\usb_storage
    C:\>dir t:
     Volume in drive T is USB_Storage
     Directory of T:\
    11/10/2017  09:25 PM       423,489,144 Audio_Driver_PKGMR_WN32_6.0.1.7564_A01.EXE
    C:\>net use
    New connections will be remembered.
    Status       Local     Remote                    Network
    OK           T:        \\readyshare\usb_storage  Microsoft Windows Network
    C:\>net use t: /d
    t: was deleted successfully.
    What I did was assign the share to my PC's T: drive. I can do whatever I wish with it now direct from my PC. The NET USE will show you what is used too. the command with the drive a /d will release the drive letter.
    All you have to know is the SERVER name shown on NET VIEW, and the share names on the individual devices. On possible drawback (same as using the LAN method to access another PC) is you'll need ACCESS to the shares, which you probably already have.
    Another thing, unless you've set up RESERVED IP ADDRESSES you can not rely on using the IP Address method as they can change depending on which device comes on-line first. In my case I did reserve specific IP addresses for ALL PC's.
    Hope this helps. Reply back if you need more info or details.
  • > I have 2 PC's connected to my router. [...]
       Windows?  Version(s)?
       "can't see" is not a useful problem description.  It does not say
    what you did.  It does not say what happened when you did it.  As usual,
    showing actual actions with their actual results (error messages, LED
    indicators, ...) can be more helpful than vague descriptions or
    interpretations.
    > [...] Each showed their own PC device, 3 cell phones, one printer and
    > one Xbox device.
       "Each" _what_ showed what, exactly?
    > the Desktop device.
       At what, exactly, are you looking?
  • Running Windows 10 by any chance?
    If so you need to enable SMB1 Client on all W10 PC's. Control Panel, Programs and Features, Turn Windows Features on or off,  scroll down to SMB 1.0/CFS File Sharing Support, open it and enable the Client. Should fix the problem.
    • Jim_Elma's avatar
      Jim_Elma
      Tutor
      I am running Windows 10 v1709 on both machines.
      My research on the web when this issue started last week suggested that I turn on the SMB1 client on all PC's which I did. Following that change I was able to see all the PC's on the network. However, that was apparently a temporary band-aid fix as it is no longer working.
      As I tried to explain in my original inquiry, we have a total of 7 devices in our household that could link to the network when active. This includes the following:
      2 - PC's (Desktop & Laptop)
      3 - Cell Phones (mine, wife, son)
      1 - Printer (wired to desktop, Bluetooth to laptop)
      1 - Xbox (son's games)
      When I log into the Netgear Web Admin service from my Desktop and view the devices attached to the network, it gives me an icon and IP addresss for 6 devices on the network. The missing device is the Laptop (even though it is on and active).
      When I log into the Netgear Web Admin service from my Laptop and view the devices attached to the network, it gives me an icon and IP addrress for 6 devices on the network. The missing device is the Desktop (even though it is on and active).
      FYI - When I read about SMB1, it said that this was a change that Microsoft made to protect businesses for security purposes. They knew it would impact home users but put the change in anyway. It said that home users security would be at risk is this was turned on. I turned it on anyway.
      • Jim_Elma's avatar
        Jim_Elma
        Tutor
        One additional note:
        When I turned on SMB1 client, I also turned on these additional related switches:
        SMB1 Server
        SMB1 Automatic Removal
        Is it possible that these are causing my issue ?
