shubham7646
Jul 07, 2023Follower
Unable to Connect to R6700v3 After Factory Reset
After Factory resetting a R6700v3, and attempting to connect to it, each time I try to connect to what I presume is the router (the default wifi network name is now showing up) it says the code is wr...
Jul 07, 2023Guru - Experienced User
So you're currently going isp gateway--->R6700?
sometimes the routerlogin won't work if running through your isp device being in a double nat.
Disconnect it from the att device and reboot it. Then connect to it (wired) and try accessing the routerlogin
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
