TropicPlague
Jan 06, 2024Tutor
Unable to connect to the internet and routerlogin.net won't display
I have a new AC1750 (R6700 v3) router that I'm trying to set up and I'm running into issues which I'm not sure are related or not. The router does not connect to the internet even after performing th...
- Apr 09, 2024
My 'solution' was to just purchase another router. Everything I tried to fix the Nighthawk router failed.
Kitsap
Apr 09, 2024Master
There are a lot of options in the following linked document.
https://kb.netgear.com/27199/I-can-t-access-my-router-what-do-I-do
modus
Apr 09, 2024Tutor
Hi Kitsap
Thanks for the quick response. I've gone through the entire thing and nothing appears to fix the problem. The issue is the same that the OP, TropicPlague, experienced.
Modus
