ras96mg
Dec 05, 2020Aspirant
Unable to connect to the internet through a router I bought on craigslist
I bought it yesterday after finding it on craigslist. Installed the all three antennas, hooked it up to my modem and I tried resetting it both on and off. The routers lights indicated a proper intern...
Mickeydanvo
Your situation exactly same mine....
First at all you need to download the app Netgear Nighthawk from your mobile or PC then register new account then install model number, series number, and password.
It's working perfectly. Good luck.
Mickeydanvo
Just make sure you can use the wifi from modem first for download the app Netgear Nighthawk after that switching to Netgear router for register new account login install model number, series number and password number.
- antinodeDec 05, 2020Guru
> [...] Arris Surfboard SB6183 [...]
> Just make sure you can use the wifi from modem [...]The ARRIS SB6183 is a _modem_, not a modem+router. By itself, it has
no "wifi".
