ras96mg
Dec 05, 2020Aspirant
Unable to connect to the internet through a router I bought on craigslist
I bought it yesterday after finding it on craigslist. Installed the all three antennas, hooked it up to my modem and I tried resetting it both on and off. The routers lights indicated a proper intern...
Mickeydanvo
Your situation exactly same mine....
First at all you need to download the app Netgear Nighthawk from your mobile or PC then register new account then install model number, series number, and password.
It's working perfectly. Good luck.
michaelkenward
Dec 06, 2020Guru - Experienced User
Registration is not necessary to setup a router. Nor is using a mobile device and Nighthawk app the best way to go about it. There is no Nighthawk app for a PC.
Registration is just for 90-day support to help you set the thing up and for the warranty support, although even there registration is not required under law.
While Netgear wants everyone to use an app for set up, experienced users prefer doing it with the browser graphical user interface (GUI) with a wired connection between a PC and the router.
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
It will also have any software, firmware and drivers for your device.
Begin with the Quick Start/Installation Guide.
