ForumsSuck
Apr 01, 2019Aspirant
unable to directly connect to my nighthawk r7000.
i have tryed to connect using 192.168.1.1 as well as http://www.routerlogin.net
for the number it just times out again and again, for the router login, it says 'your not connected to the wifi...
- Apr 01, 2019
> [...] mine it seems is 10.0.0.1 vs the normal one listed online. ;>
> it let me using thatOk, but the reason the R7000 shifted from its normal default
("192.168.1.1") to that alternate is, most likely, that you connected it
to some other router (which was already using the "192.168.1.*" subnet).> To what did you connect the WAN/Internet port of the R7000?
Still wondering.
Cascading multiple routers can cause multiple problems.
https://community.netgear.com/t5/x/x/m-p/1684723
Without knowing what your mystery device (modem/router?) is, it's
tough to give more specific advice.
ForumsSuck
thank you. mine it seems is 10.0.0.1 vs the normal one listed online. ;> it let me using that
antinode
Apr 01, 2019Guru
Still wondering.
