ForumsSuck
Apr 01, 2019Aspirant
unable to directly connect to my nighthawk r7000.
 i have tryed to connect using 192.168.1.1 as well as http://www.routerlogin.net
 for the number it just times out again and again,   for the router login,  it says 'your not connected to the wifi...
- Apr 02, 2019
> [...] mine it seems is 10.0.0.1 vs the normal one listed online. ;>
> it let me using thatOk, but the reason the R7000 shifted from its normal default
("192.168.1.1") to that alternate is, most likely, that you connected it
to some other router (which was already using the "192.168.1.*" subnet).> To what did you connect the WAN/Internet port of the R7000?
Still wondering.
Cascading multiple routers can cause multiple problems.
https://community.netgear.com/t5/x/x/m-p/1684723
Without knowing what your mystery device (modem/router?) is, it's
tough to give more specific advice.
antinode
Apr 02, 2019Guru
Still wondering.
ForumsSuck
Apr 02, 2019Aspirant
my apologies for not giving you that information.
basically i have it connected to the att internet router box. i am using my personal router for wifi and connection instead of theirs for the ability to control / lockout people on the wifi, and to make it easier for me to share the connection with the freinds i wish to do so. basically its 'internet line into the house into the att router, to my router to my computer all cable connected (nothing like frying them all if i get a ground lighting strike in the right spot right? :>)
that and theres has a very low level of connectivity where as the nighthawk has more connections available
