Zedrick
Jun 20, 2020Aspirant
Unable to download GUI language
I'm going through Netgear genie and trying to download the latest firmware. Version info below. When I click yes to start the update it says: "Unable to download GUI language from file from N...
- Jun 22, 2020
Go for a manual update. More reliable and safer.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware for your device.
The manual explains how to do a manual update. The release notes should also help.Then this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
michaelkenward
Jun 22, 2020Guru - Experienced User
Support | NETGEAR
Then this:
- ZedrickJun 23, 2020Aspirant
Thanks very much. Cheers
