PatrickE2
Mar 18, 2021Guide
Unable to download windows updates when connected to r7000
I have an odd issue. Starting a couple of months ago I can no longer download windows updates when connected to the router. This is true for all PC's in my home (4). Windows update will recognize tha...
Mar 18, 2021Guru - Experienced User
Have you tried a different dns provider?
Try googles at 8.8.8.8 or 8.8.4.4
cloudfare: 1.1.1.1
what modem/gateway do you have?
- PatrickE2Mar 18, 2021Guide
I am connected to a smart hub ZTE MF279T, and I have already tried Cloudfare and Google both on router level and device.
- plemansMar 18, 2021Guru - Experienced User
that hub has its own integrated router functions.
do you have it in passthrough/modem only mode?
or the Netgears IP address in its DMZ?
or the netgear in access point mode?otherwise you're running a double nat.
Yes it's in passthrough. No problems with automatic updates for other software, only windows update.
