PatrickE2
Mar 18, 2021Guide
Unable to download windows updates when connected to r7000
I have an odd issue. Starting a couple of months ago I can no longer download windows updates when connected to the router. This is true for all PC's in my home (4). Windows update will recognize tha...
PatrickE2
Mar 18, 2021Guide
The ZTE's router is junk. Does not show IP's on connected devices, only mac address.
PatrickE2
Mar 19, 2021Guide
Ended up resetting the router, entered in IP manually, then back to AP mode. Seems to be working fine now, but sad not to be able to use any of the routers features such as QoS, access control etc.
- plemansMar 19, 2021Guru - Experienced User
If the zte had better or even just properly function settings, would could get it working.
Its sad when you're limited because of other equipment.
