Oscar400
Nov 01, 2019Follower
Unable to enable QoS to my router
So I just did a factory reset on my router and when I went to change the settings on my router (enable QoS)and it doesn’t work It tells me ”The speed test fails to detect the bandwidth , please check ...
- Nov 01, 2019
There is nothing you can do. This is a bug in the firmware. It's been patched in some models, like the R7800, but in others it isn't. You'll have to define your upload/download speeds manually to get QoS working
microchip8
Nov 01, 2019Master
