Mohan3321
Mar 13, 2024Follower
Unable to find 5Ghz on the following router R8000P
Unable to find 5Ghz on the following router R8000P 5G-2 channel shows 0 and 5G-1 channel shows some unrecognised character, i tried factory reset and update to latest firmware and also tried to downgrade the firmware it did not work out, 5G wont show up, my region is india please if there is any fornware for my region attach the link that would help me, please help me to fix the issue.
1 Reply
Try a 30-30-30 reset on the router. If this fails to bring back 5Ghz SSID, possible the radio has gone bad.
