thedogger35
Sep 23, 2020Guide
Unable to get r7000 into reset mode to re-flash bios to OEM from DD-WRT
Have a r7000-AC1700 that curently has DD_WRT on it and I am trying to flash it back to the original OEM initial release of Netgear BIOS I am unable to get the R7000/AC1900 to go into reset to allow ...
- Sep 24, 2020
Finially Success
.\nmrpflash -i net2 -f R7000-V1.0.0.96_1.0.15.chk
Advertising NMRP server on net2 ... -
Received TFTP_UL_REQ while waiting for CONF_REQ!
Received upload request without filename.
Uploading R7000-V1.0.0.96_1.0.15.chk ... OK
Waiting for remote to respond.
Received keep-alive request (16).
Remote finished. Closing connection.
Reboot your device now.
PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ipconfigWindows IP Configuration
Ethernet adapter Npcap Loopback Adapter:Connection-specific DNS Suffix . :
Autoconfiguration IPv4 Address. . : 169.254.87.4
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :Ethernet adapter Ethernet:
IPv4 Address. . . . . . . . . . . : 192.168.1.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ping 192.168.1.1 -t
Sep 24, 2020Guru - Experienced User
I'd ask on the dd-wrt forum. They're the experts on their firmware and how best to remove it without bricking your device.
labatt
Sep 24, 2020Mentor
Since there is no back to stock firmware listed this may mean that Brainslayer has added code to reinstall Netgear firmware. Have you tried to install a Netgear firmware?
2 Years ago I wound up having to use a serial to USB cable to reinstall Netgear firmware. I never got tftp to work to get back to Netgear. Yes I have successfully used tftp when the firmware was Netgear, to answer those that ask have you ever successffully done a tftp. ;)
