thedogger35
Sep 23, 2020Guide
Unable to get r7000 into reset mode to re-flash bios to OEM from DD-WRT
Have a r7000-AC1700 that curently has DD_WRT on it and I am trying to flash it back to the original OEM initial release of Netgear BIOS I am unable to get the R7000/AC1900 to go into reset to allow ...
- Sep 24, 2020
Finially Success
.\nmrpflash -i net2 -f R7000-V1.0.0.96_1.0.15.chk
Advertising NMRP server on net2 ... -
Received TFTP_UL_REQ while waiting for CONF_REQ!
Received upload request without filename.
Uploading R7000-V1.0.0.96_1.0.15.chk ... OK
Waiting for remote to respond.
Received keep-alive request (16).
Remote finished. Closing connection.
Reboot your device now.
PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ipconfigWindows IP Configuration
Ethernet adapter Npcap Loopback Adapter:Connection-specific DNS Suffix . :
Autoconfiguration IPv4 Address. . : 169.254.87.4
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :Ethernet adapter Ethernet:
IPv4 Address. . . . . . . . . . . : 192.168.1.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ping 192.168.1.1 -t
thedogger35
Sep 24, 2020Guide
Thanks for the response, I get posting on the dd-wrt forum, but the issue is that the r7000 will not go into reset mode.I cant get the power light to blink orange.
That is the real issue.
Sep 24, 2020Guru - Experienced User
have you tried nmrpflash?
- thedogger35Sep 24, 2020Guide
Thanks but I dont see a D/L for Win10 64-bit
Dont have a MAC or Linux to run other version- plemansSep 24, 2020Guru - Experienced User
the 32bit program will run on your 64bit windows machine.
Ya right now bird dogging this error
"The program can't start because wpcap.dll is missing" (Windows)"
Installed ncap and still get the dam error trying to run the exe
Finially Success
PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ping 192.168.1.1 -t- plemansSep 25, 2020Guru - Experienced Userglad to hear you got it working!
- thedogger35Sep 25, 2020Guide
OH its far from fixed, now have to see if the Advanced Tomato help with thnotoriously disapearring 5GWiFi issue that Netgear fails to acknowledge and either fix or admit that there is a hardware issue with the R7000
