thedogger35
Sep 23, 2020Guide
Unable to get r7000 into reset mode to re-flash bios to OEM from DD-WRT
Have a r7000-AC1700 that curently has DD_WRT on it and I am trying to flash it back to the original OEM initial release of Netgear BIOS I am unable to get the R7000/AC1900 to go into reset to allow ...
- Sep 24, 2020
Finially Success
.\nmrpflash -i net2 -f R7000-V1.0.0.96_1.0.15.chk
Advertising NMRP server on net2 ... -
Received TFTP_UL_REQ while waiting for CONF_REQ!
Received upload request without filename.
Uploading R7000-V1.0.0.96_1.0.15.chk ... OK
Waiting for remote to respond.
Received keep-alive request (16).
Remote finished. Closing connection.
Reboot your device now.
PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ipconfigWindows IP Configuration
Ethernet adapter Npcap Loopback Adapter:Connection-specific DNS Suffix . :
Autoconfiguration IPv4 Address. . : 169.254.87.4
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :Ethernet adapter Ethernet:
IPv4 Address. . . . . . . . . . . : 192.168.1.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ping 192.168.1.1 -t
Sep 24, 2020Guru - Experienced User
tried it myself on my windows 10 64bit computer and was able to use it.
Not sure exactly what you're doing wrong.
thedogger35
Sep 24, 2020Guide
Got it up and running, Ill update how it goes...my hope is that flashing this back into OEM firware then to advanced tomato I moght be able to get ride of the issue that netgear does not want to admit to with the G5 wireless always failing
Thought that I resolved it with the dd-wrt but issue persisted, has to be hardware. If the Tomato does nto fix it then its going in the trash
