thedogger35's avatar
Sep 23, 2020
Unable to get r7000 into reset mode to re-flash bios to OEM from DD-WRT
Have a r7000-AC1700 that curently has DD_WRT on it and I am trying to flash it back to the original OEM initial release of Netgear BIOS I am unable to get the R7000/AC1900 to go into reset to allow ...
  • thedogger35's avatar
    thedogger35
    Sep 24, 2020
    Finially Success
    .\nmrpflash -i net2 -f R7000-V1.0.0.96_1.0.15.chk
    Advertising NMRP server on net2 ... -
    Received TFTP_UL_REQ while waiting for CONF_REQ!
    Received upload request without filename.
    Uploading R7000-V1.0.0.96_1.0.15.chk ... OK
    Waiting for remote to respond.
    Received keep-alive request (16).
    Remote finished. Closing connection.
    Reboot your device now.
    PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ipconfig
    Windows IP Configuration
    Ethernet adapter Npcap Loopback Adapter:
    Connection-specific DNS Suffix . :
    Autoconfiguration IPv4 Address. . : 169.254.87.4
    Subnet Mask . . . . . . . . . . . : 255.255.0.0
    Default Gateway . . . . . . . . . :
    Ethernet adapter Ethernet:
    IPv4 Address. . . . . . . . . . . : 192.168.1.10
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ping 192.168.1.1 -t
